Excessive Gas In Furnace Burner Trays. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 11:08 PM   #1
Excessive gas in furnace burner trays.
I'm getting excessive amounts of gas in the burner trays. Do I need to replace the gas valve?
Dr. Hugo is offline   Reply With Quote
Old 01-24-2012, 11:18 PM   #2
how
Rewards Points: 1,104
Dr Hugo!
What makes you think that you are getting excessive gas in the burner trays?
A manometer test looking for 3.5" WC from the gas valve outlet (if we are talking about natural gas) is the usual test.
A heat exchanger blockage or a cracked exchanger or anything limiting the vent inlet/ outlet flow can make it look like the burner tray is getting excessive pressure.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
harleyrider (01-24-2012)
Pilot burner replacement - Carrier 58GS150-CB furnace danielr HVAC 11 02-08-2013 12:19 PM
Sears GAs furnace issue with burner running too long dmanmtl HVAC 17 01-03-2012 09:41 PM
furnace burner problem brent h HVAC 2 01-11-2010 07:50 PM
Tappan Furnace burner problem Ruffuss HVAC 0 09-28-2009 10:14 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
