Excessive Furnace Cycling - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 09:44 AM   #1
excessive furnace cycling
Gas flame turns off after 4-5 minutes, even though thermostat has not been satisfied. After blower turns off, the same cycle repeats. Service technician suspected restricted air flow, but problem persists after cleaning furnace, ducts, evaporator coils.
dbeerman is offline   Reply With Quote
Old 11-27-2010, 09:53 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 386
Did he do a temp rise test to see if it is within recommended specs for the furnace? A good tech will sit there and run it for 15 mins to see if it is cycling on the limit control.
The Following User Says Thank You to yuri For This Useful Post:
dbeerman (11-27-2010)
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Problem with Burnham Oil Furnace short cycling Catherine M Brown HVAC 13 01-29-2009 10:58 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Proportional cycling for gas furnace Ultrarunner2017 HVAC 7 11-11-2008 07:56 AM
