Exaust Venting For Older LP Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2013, 02:47 PM   #1
Exaust venting for older LP Furnace
I have a lake cabin that I am building. Here are the facts:
  • It is 960 sqare feet with an unfinished walkout basement.
  • The basement will have infloor heat with an electric boiler.
  • For right now I will have a older forced air LP Gas furnace.
  • It is not high effiency.
  • It has a 3" fan powered exaust on it
  • It is located in the middle of the basement.
  • I want to vent it horizontaly
I know I will have to use the double walled metal pipe, but Is there any trick to this other than running up into the floor joice webbing and then routing it outside with a thimble collar? What kind of termination do I need to put outside?
I would like to run it out the side of the house so it would be about a 20 foot run on a straight shot. Should the pipe be level or have a slant up?
Thanks for any help that can be given.
Peter
PS pardon any spelling errors. I have not installed the spell checker yet.
petermb72 is offline   Reply With Quote
Old 11-19-2013, 07:55 PM   #2
Any Ideas?
Old 11-19-2013, 08:02 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
you cannot vent them horz out any wall. there is a expensive Tjernlund add on power vent kit but it has to be installed by a Pro and can cause problems with the furnace if not setup properly. they are UL and gas code approved for vertical venting only w/o that aftermarket device. I don't sell them but if you can find a Pro that does go 4 it.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Furnace and Water Heater Venting SallySensation HVAC 5 03-05-2013 06:53 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 06:51 PM
Horizontal Venting of Wood Furnace ejfitzpatrick HVAC 2 10-17-2009 07:16 PM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 01:48 PM
