Everything Runs, But Pressure Still Equalized? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 08:41 AM   #1
Everything runs, but pressure still equalized?
Hey everyone ! Here are the facts:
York H1DH Condenser (see attachments for info)
Bristol H25B203 Compressor
Had a GE 30/4 Dual Run capacitor (good), replaced with a 35/5 Dual Run capacitor (as stated in York H4DH parts manual)
Phillips Start capacitor (too old to read label)
R-22
only 17 years old (ok, that just put things into perspective)
Everything runs, the compressor is making a slight rattling noise, but the high and low sides are still equalized (around 110 psi). The 'system' stop working two years ago, and I'm sure it make a loud screech at some point, and sometimes it came on with a 'pop'. The actually sequence of sounds is a little fuzzy now.
Power source voltage good (244v)
No line voltage across C and R
All the continuity checks across the relay, contactor, and compressor terminals pass.
Amp draws during operation:
R - 5.6A
S - 5.8A
C - 1.7A
Fan - 0.5A
Fan motor thermostat - 0.8A
L1 - 2.4A
L2 - 2.4A
Diagnosis?
Is the compressor supposed to be drawing amps from both R and S? Their total, 11.4A equals the RLA.
Thanks everyone!!!
Everything runs, but pressure still equalized?-condenser-label-compressed.jpg   Everything runs, but pressure still equalized?-condenser-schematic-compressed.jpg
krosselle is offline   Reply With Quote
Old 05-30-2009, 10:36 AM   #2
HVAC / Plumbing
sounds like the compressor just gave up
kenmac is offline   Reply With Quote
Old 05-30-2009, 12:19 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it obviously is not pumping enough of anything to pressurize the system so that means either the comp is not running nearly fast enough to pressurize or the comp is just plain busted and not pumping anything
with the running current so low, I would suggest the pump portion of the comp has broken something and the motor is simply free running.
time for a new comp, or at that age, a new unit altogether.
Old 05-30-2009, 02:14 PM   #4
An old Tradesmen
Rewards Points: 6,870
Yes, it should draw amperage on the start wining wile running.
Sounds like it lost a vlalve.
Old 05-30-2009, 04:36 PM   #5
Tired & Dirty
Rewards Points: 83
yup, prolly a warped valve. Have replaced a few Bristols in the past with this problem.
evapman is offline   Reply With Quote
Old 05-30-2009, 05:03 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
Bristols, Ptui, I despise them. The internal relief valve may have popped open and is stuck open. Give the can a good whack upside the head with a rubber mallet and it may reset. Probably need a new compressor/unit anyway.
Old 06-01-2009, 09:22 AM   #7
Thanks everyone, I'll go the new condenser unit route. After I whack it with the mallet
Old 06-01-2009, 09:23 AM   #8
Do I whack it while it is running?
Old 06-01-2009, 03:32 PM   #9
Hvac Pro
yuri's Avatar
Try it B4 starting it and then later. Less than 5% chance it will work. Would have to be caused by a restriction in the system causing it to pop. Then you have another problem to fix.
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 09:43 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
well pump wont hold pressure jakjkl Plumbing 6 12-20-2008 09:11 AM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
