Evaporator Water Blowoff - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 09:26 AM   #1
evaporator water blowoff
we have a down flow furnace, the water is being blow off the a coil straight into the duct work, we have turned down the speed on the blower, any suggestions?
red0804 is offline   Reply With Quote
Old 07-28-2011, 04:42 PM   #2
Next step is to clean the evap coil. Doesn't take hardly any cooking oil residue or candle wax to make a down flow act exactly like yours.
The Following User Says Thank You to Marty S. For This Useful Post:
red0804 (07-28-2011)
Old 07-29-2011, 12:30 PM   #3
evaporator clean
well cleaned that today, with no change
Old 07-29-2011, 07:43 PM   #4
An old Tradesmen
Rewards Points: 7,794
How did you clean it? Just brushed it, vacuumed it, or did you use a chemical to penetrate it.
Old 07-29-2011, 09:42 PM   #5
evaporator clean
I cleaned it with 409, Im sure I used plenty, as it was dripping out when I turned it on, so it too was blowing out! The heating and cooling guys were pretty sure thats what it was too, so now they are also stumped..
Old 07-30-2011, 04:09 AM   #6
An old Tradesmen
Remove the coil panel. And use a clear plastic covering in its place. Run the system, and see if its from air blowing under/between the coil and drain pan, or if its blowing off the coil,
Old 07-30-2011, 08:00 AM   #7
evaporator water
it is definately blowing right off the coil, and splashing everywhere, I removed my duct work that is connected to the trunk to see inside...
Old 07-30-2011, 08:26 AM   #8
An old Tradesmen
Has anything else been changed in the last 3 or so months.
What is the air temp difference across the coil.
Old 08-02-2011, 10:27 PM   #9
evaporator blowoff
woohoo! may have found the problem, holding my breathe yet, duct work coming off furnace was not insulated and also had a hole in the back of it...that was 2 AC guys later! thanks for your input
Old 08-03-2011, 05:19 PM   #10
water blow off
good thing i didnt hold my breathe to long, 12 hours later the water started flowing again.........
Old 10-07-2011, 12:43 PM   #11
Have the coils been coated at all either at the factory before installation or after installation with a product such as Cal-Shield or Microguard?
appspeccrt is offline   Reply With Quote
Leaking T&P blowoff valve Termite Plumbing 7 05-19-2008 09:21 AM
