-   -   Evaporator unit is out under the house (http://www.diychatroom.com/f17/evaporator-unit-out-under-house-79960/)
randyloy 08-29-2010 04:29 PM
I have a split AC system.......A Trane High Efficiency Heat Pump XE 1000 on the outside and don't know what is under the house.......crawl space minimum.....AC went out......was told by repairman the motor relay unit went out under the house.....he replaced that and also a computer card......he said the unit was rusted out........needed to be replaced......unit still not working properly...not cooling...line to outside compressor is frozen but unit fan is still running........
What is my best way to go? The XE 1000 appears to be fine......the inside unit which also has the heater for the house appears to need replacement.....do I replace everything? Get one stand alone unit for outside the home........or replace the unit under the house (if we can get to it)....
How do you find compatible evaporator units for the XE 1000?
I am strickly a novice......need some direction........Thanks
beenthere 08-29-2010 05:33 PM
Your coil is probably dirty, or if there is a filter in the air handler, it may be too dirty.
You may want to go with a package unit for easy service down the road if you chose to replace your system.
