Evaporator Pan - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 08:34 AM   #1
evaporator pan
my evaporator drain pan does not drain untill unit turns off. condensate backs up and drips over pan. i have cleaned the drain and i cant figure out why the water will not drain until the unit is turned off
fireman39576 is offline   Reply With Quote
Old 08-20-2011, 08:55 AM   #2
biggles's Avatar
this is a exsisting unit not a new install? and your talking about the pan inside the air handler...sorry have to ask
Old 08-20-2011, 09:14 AM   #3
fabrk8r
fabrk8r's Avatar
The drain trap may be improperly configured. Can you post a pic?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-20-2011, 11:24 AM   #4
sounds like ur evaporator blower motor is sucking up air through your drain lines. can you check if there are any openings in your drain system? also check to see if you have a P-trap
Final Notice is offline   Reply With Quote
