Evaporator Fans Motor Different Speeds - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2010, 10:08 PM   #1
Evaporator fans motor different speeds
Can anyone please help me understand how the different evap fan motor speeds affect the unit.
Dennis Diaz is offline   Reply With Quote
Old 05-06-2010, 06:35 AM   #2
An old Tradesmen
Rewards Points: 8,992
High------------------Medium-----------Low
Moves the most air, moves less air, moves the least air.
The speeds are to be used to move the right amount of air for the heating or cooling load your house has.
Old 05-06-2010, 05:33 PM   #3
Determine the correct amount of air by checking system static pressure and using blower data supplied by the mfr. and matching cfm to unit size.
Too little air and the superheat is too low which can slug the compressor with liquid . Too much air and the system doesn't dehumidify properly. The most expensive system in the world is junk if not set up right.
ceiling fan speeds catlvr Electrical 4 04-10-2010 08:15 AM
