Evaporator Coil Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2017, 07:46 PM   #1
Rewards Points: 8
evaporator coil plenum
The threaded fitting from my internal drain pan has rusted out so I need to replace it. I'm not sure what type of connections the discharge plenum and coil plenum have as it is all covered with mastic. I'm guessing it is not the slip and drive connections, would it be those push together type? The mastic is pretty thick but I don't see any screws.
Bwanap is offline   Reply With Quote
Old 04-20-2017, 08:02 PM   #2
Rewards Points: 8
Re: evaporator coil plenum
Actually maybe there are screws on closer look.
Old 04-21-2017, 07:20 AM   #3
Rewards Points: 226
It's hard to tell what's going on there. That mastic is terrible. Maybe some pics further away would help.
Wilbits is online now   Reply With Quote
Old 04-24-2017, 08:20 PM   #4
Rewards Points: 8
Sorry, life got in the way. More pics attached. I put the black caulk around the drain connections but it did not help, you can see it is likely just filling pan inside and dripping into plenum and exterior tray. HVAC guy told me that if its taken apart the coil will need to be replaced because its old and will likely get damaged and therefore condenser needs to be replaced also. It's true it is old, but I read this is a pretty common statement by some repairmen. I'd like to at least see if I can replace pan. At very least if I open it up I've cut out an hour or so of labor.
evaporator coil plenum-img_0269.jpg   evaporator coil plenum-img_0271.jpg   evaporator coil plenum-img_0270.jpg
Old 04-25-2017, 11:24 AM   #5
Rewards Points: 226
Can you cut the insulation on the drain pipe back so we can see what's there ? Normally the pan will have a PVC fitting on it.
Old 04-25-2017, 06:41 PM   #6
Rewards Points: 8
There must have been a steel nipple in it because it was completely rusted. I did not think about the pan on female being plastic, I will have to try cleaning that out. Currently I siliconed it all together so peeling back insulation wont show you anything.
Check duct plan plus plenum in closet ? bocar HVAC 10 07-01-2016 04:16 PM
Plenum maximum output ang1dust HVAC 9 08-11-2012 04:20 AM
plenum dimensions Hermand HVAC 5 03-10-2011 12:24 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 10:20 AM
Plenum Design winkydink HVAC 1 11-22-2006 10:28 PM
