Evaporator Coil Measurement With Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 11:14 PM   #1
Evaporator coil measurement with gas furnace
I have a Rheem gas furnace (24yrs old). It is located in a closet in hallway with the evaporator coil for my 14 yr old 3.5 ton Carrier A/C on top of it. The coil has leaked and I was told I need to replace it. I was also told that the evaporator coil is too wide(22")for over my furnace that is 17" wide. My closet is 24 " wide. I'm looking to replace the a/c and gas furnace and hopefully get a tax break too. Did the contractor put the wrong size evaporator coil 14 yrs ago? I live in Georgia. What is opinions on a/c & gas heat verses heat pump with gas heat as duel fuel? I haven't been able to get a "matched" system due to my closet size. Guurrr. Thank you for your help on this.
softsoc is offline   Reply With Quote
Old 08-11-2010, 06:35 AM   #2
Duel fuel is very nice and effecient. If it saves much $ or not depends on your gas and electric rates.
Old 08-11-2010, 08:09 AM   #3
Licensed Master Plumber
24 years old. Tear it all out and replace it.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 08-11-2010, 06:41 PM   #4
Rewards Points: 150
read the post before replying.
johnnyboy is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
