Old 05-28-2010, 11:12 PM   #1
Evaporator coil drain pan?
My furnace and coil are very old. When we turned on the AC we found that water was leaking down the furnace instead of down the drain line. I pulled out the drain pan to find it had rusted through in several places. Can I replace this with a plastic pan? This is a natural gas furnace.
forsmant is offline   Reply With Quote
Old 05-28-2010, 11:56 PM   #2
Don't know about a plastic pan. Some of the metal replacement pans are still available and some are not. Seems like anything over 20 years old is nearly impossible to find a pan for.
Old 05-29-2010, 06:13 AM   #3
An old Tradesmen
You can have a sheet metal shop fabricate a new metal pan. But you won't find a plastic pan made today that will fit up to your old coil.
Old 05-29-2010, 11:37 AM   #4
Thank you for your replies. We are going to fabricate a pan on Sunday.
Old 05-29-2010, 12:45 PM   #5
i had the same problem with my secondary drain pan. i just went to lowes and picked up a roll of galvanized sheet metal, cut it to fit the bottom of the pan and silicone sealed it to the bottom and around the edges. it's been working fine ever since.
NitroNate is offline   Reply With Quote
Old 05-29-2010, 02:01 PM   #6
An old Tradesmen
Did you fix the problem that caused it to rust.
Since a secondary pan shouldn't get water in it to rust out.
Old 05-29-2010, 03:18 PM   #7
yeah the main drain was backing up and the secondary pan was installed incorrectly so all the water was sitting in the pan on one side for a long period of time, rusting it out slowly. after i fixed it i re-installed it correctly and unclogged the main drain.
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
