Evaporator Coil Cleaning Help - HVAC - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 09:49 PM   #1
Hi,
I noticed a musty smell when I turn on the AC, so I researched and found that my evaporator coil might need to be cleaned. So I opened up the panel where it should be, and it looks very different from the ones i have seen online. The ones I have seen are A-framed, and either this one has only one side or the other side is obscured and I need to take more things apart to get to it completely. Can someone look at the photos and let me know if what I see is the entire thing, or how I could access the other side of it? It is a Goodman unit from 2007.
thanks
picsaro is offline   Reply With Quote
Old 06-03-2013, 09:58 PM   #2
Rewards Points: 616
you need to access the side the air enters.....I can not tell from the pictures... sorry old eys
carmon is offline   Reply With Quote
Old 06-03-2013, 10:08 PM   #3
Rewards Points: 70
do a google search for "dirty sock syndrome"
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 06-04-2013, 12:40 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
you need to see it from the internal side. That is an a-frame, but you're seeing and accessing the outer side. That's not the side that clogs up. Might need to remove the return air plenum to access.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-05-2013, 04:53 AM   #5
An old Tradesmen
Rewards Points: 7,400
To my weak eyes, it looks like that coil is mounted to a gas furnace. If so, opening/removing the return plenum won't get access to the evap.
Old 06-05-2013, 04:53 AM   #6
An old Tradesmen
See if top panel of coil will come off.
Duct Cleaning mdbutterfield HVAC 3 09-10-2012 12:42 PM
Mother in law coil cleaning digitalplumber HVAC 8 08-13-2012 06:31 PM
In-Floor Swimming Pool Cleaning System Silkcityflorida Plumbing 0 03-22-2012 11:21 AM
can bad cleaning destroy your furnace eolsunder HVAC 1 09-22-2011 02:52 PM
