-   -   Evaporator Coil Cleaning Help (http://www.diychatroom.com/f17/evaporator-coil-cleaning-help-181243/)
picsaro 06-03-2013 10:49 PM
4 Attachment(s)
Hi,
I noticed a musty smell when I turn on the AC, so I researched and found that my evaporator coil might need to be cleaned. So I opened up the panel where it should be, and it looks very different from the ones i have seen online. The ones I have seen are A-framed, and either this one has only one side or the other side is obscured and I need to take more things apart to get to it completely. Can someone look at the photos and let me know if what I see is the entire thing, or how I could access the other side of it? It is a Goodman unit from 2007.
thanks
carmon 06-03-2013 10:58 PM
you need to access the side the air enters.....I can not tell from the pictures... sorry old eys
digitalplumber 06-03-2013 11:08 PM
do a google search for "dirty sock syndrome"
Doc Holliday 06-04-2013 01:40 AM
you need to see it from the internal side. That is an a-frame, but you're seeing and accessing the outer side. That's not the side that clogs up. Might need to remove the return air plenum to access.
beenthere 06-05-2013 05:53 AM
To my weak eyes, it looks like that coil is mounted to a gas furnace. If so, opening/removing the return plenum won't get access to the evap.
See if top panel of coil will come off.
