Evap Coil Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 10:38 AM   #1
I recently made the decission to repair versus replace the evap coils in my split-systems. The Plenum / Air handler (sheet metal encasement) appears to be butchered and is leaking cold air into my attic. I understand that evap coils are not always easily accessable, but what I don't know is the "standard proceedure" for puting the system back together afterwards. Some folks talk about sheet metal fabrication to close up the evap coil access holes, what I have is a butt load of HVAC tape.
Rickhoff is offline   Reply With Quote
Old 08-24-2009, 03:09 PM   #2
It's not clear as to who did the repair on the coil, yourself or a tech.
If the AH is positioned correctly you should be able to remove the coil by removing the AH panels.
So what is the question, how to repair the coil or close the AH?
hvaclover is offline   Reply With Quote
Old 08-24-2009, 05:10 PM   #3
newtech's Avatar
Rewards Points: 164
Can you post a pic??? Not exactly sure of the question, sorry....
newtech is offline   Reply With Quote
Old 08-24-2009, 09:58 PM   #4
Post some pics.
cralx2k is offline   Reply With Quote
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
Accessing evap coil - creating a reusable access panel bifjamod HVAC 1 07-07-2009 12:14 PM
Replacement furnace, add AC coil now?? NJ user HVAC 5 02-05-2009 07:45 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Access to CPC13H evap coil.. bginvestor HVAC 1 06-27-2008 09:40 PM
