Originally Posted by Larry Huber
Are you saying those are the specs for the Essex Potential Relay I referenced in my post?
No. . .sorry. . .
If these particular relay specs are not available try
http://www.supco.com/images/pdfs/Man...APR5%20man.pdf
In any case for whatever relay you put in there, you can use these ^ troubleshooting instructions to check for proper operation.
Here's the background info on it
http://www.patentgenius.com/patent/5528120.html
Ignore the "claims" section.
If you can somehow get the motor up to speed and measure the voltage across the start winding, and knowing general motor info in the patent above, the necessary relay specs for this application can probably be worked out to within 10%, which is close enough.
