-   -   Essex Potential Relay (http://www.diychatroom.com/f17/essex-potential-relay-146099/)
Larry Huber 06-05-2012 02:08 PM
I am looking for an Essex Potential Relay. It is on an Intertherm Polaris RV AC Unit and the part number on the relay is 128116-2842PB. If I just new the Pick-up and Drop-out voltage it would help greatly.
Yoyizit 06-05-2012 02:53 PM
Try
info@bender.org
If you can get the spec's, almost any relay of lesser voltage or lesser power can probably be made to work with a homebuilt two or three resistor interface network.
This is an example of what spec's you need to know
PICK UP MIN 223
DROP OUT MAX 150
CONTINUOUS COIL VOLTAGE 420
COIL DATA NOMINAL VA 5
COIL DATA MA 12
PICK UP MAX 252
Larry Huber 06-06-2012 08:34 AM
Are you saying those are the specs for the Essex Potential Relay I referenced in my post?
Yoyizit 06-06-2012 10:39 AM
No. . .sorry. . .
If these particular relay specs are not available try
http://www.supco.com/images/pdfs/Man...APR5%20man.pdf
In any case for whatever relay you put in there, you can use these ^ troubleshooting instructions to check for proper operation.
Here's the background info on it
http://www.patentgenius.com/patent/5528120.html
Ignore the "claims" section.
If you can somehow get the motor up to speed and measure the voltage across the start winding, and knowing general motor info in the patent above, the necessary relay specs for this application can probably be worked out to within 10%, which is close enough.
