Old 02-02-2007, 10:20 AM   #1
ERV vs. HRV?
energy recovery vent or heat recovery vent, which one would i use for my home in central MN. I need to lower the humidity in the winter.
Anybody in my region have these in ther homes?
brian2 is offline   Reply With Quote
Old 02-02-2007, 04:15 PM   #2
Thoroughbred Mopar Man
ERV vs. HRV?
Hi brian2
ERV stands for energy recovery ventilator, HRV stands for heat recovery ventilator. They are both the same operating piece of equipment made by different manufacturers. In most cases there is little to no difference at all.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 02-03-2007, 09:36 AM   #3
ERV vs. HRV?
I thought ERV handled humidity and HRV didn't.
On another note. You want to 'lower' the humidity in winter? Winter air is incredibly dry. My house would contract into a little ball if I didn't run a power humidifier on my furnace. What is the cause of the high humidity in your home? ERV systems are generaly used for lowering the humidity in your home in the summer.
wease is offline   Reply With Quote
Old 02-05-2007, 01:01 PM   #4
ERV vs. HRV?
wease
your house must leak enough to exchange the dry outside air into your home.
6 in. walls, low e windows, my house is airtight and just the everyday activities release moisture. breathing,cooking,bath,laundry,dishwasher. THere is only one differance that I can see in the two and that is an erv can transfer heat and moisture. hrv can only transfer heat. I figured more people would have these in there homes. As of two years ago they are required by code, in my region.
