ERV Controls - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2013, 02:04 PM   #1
ERV controls
Rube Goldberg here. I have an ERV operated by both demand switches and a percentage timer. The demand switches, in the bathrooms, run power open dampers with end switches that start the ERV. The percentage timer also operates a power open damper (balanced for airflow, although the bath ducts are not.) Small but aggravating hitch: two dampers are open more often than you'd think, and it degrades exhaust in the distant bath,
Can you buy a percentage timer with lockout rather than interlock, or is possible to rig the latter to interrupt the timed damper? Complication: The dampers are 115V.
toddmpa is offline   Reply With Quote
Sears 10" Radial need Controls 815741 part RonTay Tools 21 01-02-2016 10:30 PM
Heat Pump Controls phuz HVAC 2 01-21-2013 04:02 PM
How to stop air leaks from damper controls Rav HVAC 1 08-14-2012 08:56 PM
Parental Controls for Internet piste PC Repairs & Upgrades 7 10-20-2010 01:46 PM
Wiring question: One switch controls 2 outlets mneumann Electrical 2 12-11-2009 01:49 PM
