EPA Test In Illinios - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 04:07 PM   #1
EPA test in Illinios
How tough is this EPA test I have taken some classes but no actual prep classes for the test, if I go in pretty much cold am I pretty screwed? I need the universal
ChiMike is offline   Reply With Quote
Old 03-06-2013, 05:44 PM   #2
An old Tradesmen
Rewards Points: 6,480
Get the study book, read it, and you should pass with out a problem. Lots of dates to remember.
Old 03-06-2013, 05:48 PM   #3
Thanks a lot... trying to start working
Old 03-09-2013, 09:25 PM   #4
Rewards Points: 242
try this web site. this is who i use to give the test.
It has a free practise test. one for each section.
you want the section 608.
Each section is 25 questions. you can miss only 7 questions
per section.there is a few times that one question came up 4 times with the same 4 answers. great if you know the answer, sucks if you don't. If you know everything but the dates you will be ok.
I have been trying to get them to throw out the dates.
all but one date is about 20 years old.why do you need to know
that cfc's stopped production 19 years ago.
http://www.escoinst.com/
hvac instructor is offline   Reply With Quote
Old 03-09-2013, 09:26 PM   #5
Yeah I have taken some classes at a community college so I have learned some of the dates, thanks for the info
Old 03-09-2013, 09:39 PM   #6
Rewards Points: 242
forgot,
the prep material is a 18 page hand out. every thing you need to know is in there.
Old 03-10-2013, 08:40 AM   #7
An old Tradesmen
So you intend to work on low pressure also?
I need to test a cable for a kitchen range justplumducky Electrical 4 10-22-2012 12:23 AM
Nail Shear Strength Test ddawg16 Building & Construction 32 08-24-2012 10:17 PM
Hot Tub GFCI Test Button Not Tripping Breaker a2zunknown Electrical 7 08-20-2012 08:49 AM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
