Old 02-12-2009, 01:00 PM   #1
Enough Return Air?
2500 sqft home which was recently purchased.
Goodman 5 ton Heat Pump (Copeland Scroll) with a Variable Speed Air Handler
I don't seem to have any airflow issues at this time. However, after reading many posts here, I am concerned that I do not have enough return air to the air handler. The reurn box is approximately 24" x 24". The return configuration is as follows;
8" round return serving two bedrooms.
8" round return located in large kitchen (10' from range/ stove). This return is basically tied within two feet to the return box.
10" x 12" square trunkline that returns air from LR, DR and Family room.
As stated earlier, I get more than enough supply air to the registers. But how about the return air?
mjbxx is offline   Reply With Quote
Old 02-12-2009, 03:10 PM   #2
An old Tradesmen
Enough Return Air?
Your return duct system is too small.
Most likely, so is yur supply.
Are you judging that your supply is ok, by how hard the air is blowing out of the supplyregisters.
That is a very misleading way to do it.
Old 02-12-2009, 04:13 PM   #3
Enough Return Air?
Supply does not seem to be an issue. I have a plenum up in the attic that branches into two large trunk lines that have 8" supply ducts to all rooms and all seem to receive very good airflow. No problems keeping home comfortable. I figured the return air was lacking. How much more do I need? The return box which is 24" x 24" is split in half for access due to the subfloor. All the returns are located below the subfloor in the crawlspace. I do have access to return box above the subfloor which is approximately 12" x 24". I could run a new return to the living room which has no return vent. How does this sound and what size return should I go with?
Old 02-12-2009, 07:26 PM   #4
An old Tradesmen
Enough Return Air?
8 x 20, 10 x 16, 12 x 14. Somethng in that sq in range.
You need about another 800 CFM, of low resistance return air.
More On This Topic
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
American Gothic, or Revival-Style Gothic, was resurrected during the 1840's. The colors are mostly dark, but they're rich and fantastic. The furnishings are intricately carved and made with dark heavy woods and marble. On a small budget, naturally you... Read More »
How to Use a Duct Blaster
How to Use a Duct Blaster by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test on this house. This is a duct blaster right here. Okay the reason we are hooking up to the return side of air and maybe I need... Read More »
The rise in mega-home improvement stores has turned the ordinary homeowner into a home improvement expert. The instructions on how to perform household repairs are readily available online. All you need are the proper tools and supplies. Here's how to... Read More »
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
Basement Return Questions 108Stitches HVAC 5 02-03-2009 11:56 AM
question on return duct familyman HVAC 13 01-25-2009 12:05 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
