Enough Power For Heat Pump In Garage Renovation? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2013, 08:11 PM   #1
Rewards Points: 206
Smile
Enough power for Heat Pump in garage renovation?
We are planning to have our attached garage converted to living space. It is 450 square feet. It will be insulated floor, ceiling and all walls. We live in northern AL.
Our preference is for a conventional unit with the indoor coil and blower mounted in the attic over the garage, feeding conditioned air through ducts to vents in the ceiling.
We have 200 amp service and a dual fuel system (heat pump and gas furnace) in the house proper. At the electrical service panel, there is only one unused 250 v 'slot'. It has 30 amp fuses in it (picture attached).
Is that enough 'juice' to run a second heat pump dedicated to just the renovated garage?
Thanks.
John_W is offline   Reply With Quote
Old 09-15-2013, 01:17 AM   #2
Rewards Points: 1,192
Yeow! Fuses? Look into a mini-split heat pump.
bobelectric is offline   Reply With Quote
Old 09-15-2013, 06:47 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
It is plenty for a Zoneline unit. You know, like in a motel room.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-15-2013, 08:50 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 380
you can run a 2 ton ac off 30 amp fuses/breakers in a house and a heat pump is no different. won't need 2 tons and yeah a 1.5 ton will be too big for that space also. a smaller mini split heat pump may be required. the smallest conventional unit is 1.5 tons and can do a space twice that size. an oversized unit will short cycle badly and get damaged. the Fujitsu mini splits are very quiet indoors. they make one that works down to -15 deg F. after that you would need some baseboard heaters. LG and Mitsubishi are major players and good also.
http://www.fujitsugeneral.com/products.htm
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Craftsman 1/2hp Garage Door Opener No Power DIYfer General DIY Discussions 4 09-11-2011 09:02 AM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
Supply power to a garage in Ontario Canada StarGehzer Electrical 7 10-15-2010 12:47 PM
