EnergyStar Furnace Blower? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 09:41 AM   #1
Rewards Points: 270
EnergyStar furnace blower?
For something we use so often (forced hot air heat and A/C so we are using it all year round bsaically) is there such thing as a replacement EnergyStar blower motor. It is a ~2002 Trane XR80. On a sidenote is there any way to reclaim or reuse some of the massive amounts of heat that go up the power vent?
pcampbell is offline   Reply With Quote
Old 11-30-2008, 11:02 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,176
No and no. The new variable speed furnaces like a Lennox G61V use a special high efficiency ECM (electronically commutated DC motor) which needs a circuit board to control it and that has to be specifically designed for your furnace. No retrofits that I am aware of. If you cool down the smoke to the chimney it will condense and water will flow back to the furnace. Sorry.
Old 11-30-2008, 11:24 AM   #3
Why didn't you pop for a 90%er back in 2002?
hvaclover is offline   Reply With Quote
Old 11-30-2008, 11:48 AM   #4
An old Tradesmen
Rewards Points: 6,160
They are working on it for furnaces, but its not available yet.
That would be called a 90% furnace.
Just a FYI. That is NOT a power vent. Or it wouldn't be allowed to vent into a masonary or B vent chimney.
Old 11-30-2008, 12:14 PM   #5
Rewards Points: 270
We did not put the XR80 in... it was there when we bought the house.
The existing furnace is... I am not sure what you would call the vent. It is definitely assisted with the blower, and goes right through the roof with a steel pipe. It's not direct vent, at least in the sense that it does not draw outside air.
I do not see the XR80 going anywhere any time soon... so just trying to work with what we have. Figure if Icould swap in an EnergyStar 500 watt motor over a 1000 watt motor that gets several hours use per day, it could make a big difference. Oh well...
Old 11-30-2008, 01:53 PM   #6
An old Tradesmen
Its probably B vent.
Its only rated for negative draft systems, which is what your XR is rated for.
An inducer, on an 80%, is not a blower to blow the exhaust out the pipe.
It only creates a slight negative draft inside the heat exchanger.
If it created positive pressure to blow the exhaust out, you wouldn't be allowed to use B vent on it.
Nor would you be able to vent a water heater into the same chimney as an 80% induced draft furnace..
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 02:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 04:57 PM
