Energy Home Ventilator - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 06:34 PM   #1
Rewards Points: 81
Over the last 6 months I've taken a number of steps to try and solve an issue of temperature balancing throughout my home. I recently had a full energy audit done by an insulation company to identify issues within the home.
One of the recommendations in the report was to add an energy home ventilator b/c they said that my home is "tight" and would benefit from increased circulation of fresh air throughout the home. It was recommended I consult with an HVAC company for further details.
What does adding a ventilator essentially mean? I currently have two furnaces in the home, one for the basement and main level and one for the upstairs. Is this a piece of equipment that is added to the furnace or is a whole new major system? Any ideas on the cost of adding such a device?
Pretty clueless about all of this and just trying to further educate myself before getting too deep down the rabbit's hole.
Thanks.
ks-man is offline   Reply With Quote
Old 03-27-2012, 07:21 PM   #2
Rewards Points: 6,652
They are talking about "Air Exchanger Systems". http://search.yahoo.com/search;_ylt=...ir%20exchanger
Old 03-27-2012, 08:14 PM   #3
Rewards Points: 81
From some of those pictures it seems that adding that is a pretty significant project. What would adding a device like this entail? I was hoping it could be incorporated into my current system. My home is completely finished so I can't easily make major infrastructure changes to my system.
Old 03-27-2012, 08:30 PM   #4
It has to be incorporated into the hvac system, and that means both systems would need one. What does it entail you ask? About $1,000 each starting at the low end, and figure in cost for man hours. You can do it yourself, but better to let a HVAC company do it, so that the work is warranted.
We are looking at one, due to if our home is closed up for a long period during Winter, Air starts to get stale, because there is not enough exchange from inside to out, even though our home is leaky. Personally, I would do it, because not only are you going to get a energy rebate, you will quickly notice a difference in both the feel of the air in the home, along with the smell of the air from cooking, etc.
Old 03-27-2012, 08:52 PM   #5
An old Tradesmen
Rewards Points: 7,782
Did they tell you your infiltration rate. my have been stated as ACH 50, or ACH natural.
Old 03-27-2012, 09:02 PM   #6
Rewards Points: 81
This is straight from my report and I think what you are asking to see:
"The blower door measured 3,670 CFM50 of air being pulled in through air leaks in your home's Building Envelope. This air is coming in through gaps, cracks, cavities in and around the components that make up the home's Building Envelope (which is typical of all homes that have not been air
sealed). A conversion calculation was done to estimate your home's "Natural" Air Changes per Hour of 0.21 ACHn. The entire volume of air in you home is exchanged approximately once every 4.84 hour(s). The goal is 1 air change every 3 hours or .35 ACHn."
Old 03-27-2012, 10:41 PM   #7
Rewards Points: 380
These systems can be directly ducted to remove stale air form bathrooms, kitchens, etc. and tied back into the return air ducting of your existing system, or they can be installed in what is reffered to as a simplified method where the unit draws stale air from the house from the existing return air duct and re-introduces fresh air back into the return air duct closer to the furnace (depending on manufacturer anywhere from 3-10 ft of separation). The unit is then interlocked with your furnace fan so that the fresh air will be circulated throughout the home whenever the unit is running.
Depending on where you live you may select an HRV (typically for colder climates) or an ERV (typically for warmer climates). They come in various capacities (CFM) and make a big difference to your indoor air quality (especially if you have humidity issues in the winter time, provided you live in a colder climate).
By chance does your current system use a common return air ducting system, or are both furnaces tied into thier own dedicated return duct system?
HVACDave is offline   Reply With Quote
Old 03-27-2012, 11:55 PM   #8
Rewards Points: 81
Thanks for the information. In my current system each furnace has its own duct system. The upstairs unit has its duct work running throughout the attic. The main level and the basement has the ducts in the ceiling of the basement. I'm not sure if there are any ducts running up the walls of the main levels. I do think I have some vents high on the walls or the ceilings of the main level so I'd assume that means the ducts do travel vertically for those levels.
Old 03-28-2012, 04:18 AM   #9
An old Tradesmen
ASHRAE standards is 1 air exchange every 3 to 5 hours. You are within their standards.
Insulation and Energy Efficiency Help HomeInsulation Introductions 2 05-27-2011 09:24 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
Energy efficient new home? kcrossley2 Building & Construction 10 01-27-2007 09:04 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
