Enclosing A Furnace In A Garage - HVAC - DIY Chatroom Home Improvement Forum
Old 12-31-2009, 12:38 PM   #1
enclosing a furnace in a garage
building a garage with a living space above. Need to enclose a Goodman GMH95 high gas-fired furnace in one of the garage bays.
Questions:
1) type of door 2) vents 3) is fire rating a factor 4) may have to wire this mug...can a rookie do it?
Big Daddy1 is offline   Reply With Quote
Old 12-31-2009, 01:26 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Welcome to the Forum,
The most important thing is to be safe.
Since there are so many regional and local variations the best way to be safe is to call your Building & Safety to get your very own requirements e.g. a common requirement is that the ignition source be at least 18" above the garage floor, is this the same in your area?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-31-2009, 01:34 PM   #3
An old Tradesmen
Rewards Points: 6,124
I believe you will also find that many areas have a line of site code also.
meaning that if the garage door opens. And a car can be driven in straight and hit the furnace, You must put a bollard or some other means of stopping the car.
A 2X4 wall will qualify in one area, and not the next.
As Bob said. Check your local codes first.
Old 12-31-2009, 10:21 PM   #4
What provisions have you made to prevent freezing of furnace condensate?
hvaclover is offline   Reply With Quote
Old 01-02-2010, 07:47 AM   #5
Make sure that return air is tight , don't want to pulling any exhaust fumes from combustion engines through the system.
SULTINI is offline   Reply With Quote
Wiring a T-stat for my garage furnace. klapool HVAC 45 01-08-2009 04:47 PM
new (used) garage furnace coldnorth HVAC 11 12-31-2008 09:19 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
garage furnace mrseebro HVAC 3 01-07-2008 08:25 AM
