Enclosing Access To Duct "valves" In Basement. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 11:59 AM   #1
Master Joatmon
Chucky Jesus's Avatar
Enclosing access to duct "valves" in basement.
I am in the process of finishing my basement and want to enclose the run of ductwork that consists of the out going and return air. Within this run are those "valves" that allow me to close off each of the branches from the out going main duct. I would like to set these completely open and enclose the duct work without having to build some kind of access door to them. I would then adjust each room's air flow by adjusting the incoming register in each room instead of the valve in the basement. Those valves never seem to completely close anyway, but the registers appear to be air tight when closed. Is this kosher? BTW, with the use of that shiny aluminum duct tape and 100% silicone caulk, I have sealed every joint and connection in the duct work that I have access to in the basement (both outgoing and return ducts).
Chucky Jesus is offline   Reply With Quote
Old 08-19-2009, 02:21 PM   #2
30 year tech
hvac122's Avatar
I would recommend a suspended ceiling so you can get to the later if you ever need to. Also with the technology going like it is I would want the means to run wires and such at a later date.
hvac122 is offline   Reply With Quote
Old 08-20-2009, 06:45 AM   #3
Master Joatmon
Ducts in a row
Thanks for the reply. The ceiling and hanging duct work is going to be enclosed in stained and varnished luan 32"x32" panels with 3/4" wide trim over the seams. I guess in this area I will fasten the luan and trim to the framing I installed with screws so I can access later. It's a PITA vs. air nailer driven trim nails, but it it will serve for access purposes like you mentioned.
I don't know that much about fluid dynamics, but I was curious if it mattered whether I close off a zone at the branch origin (basement) or the branch end (register in the room).
CJ
Old 08-21-2009, 02:32 PM   #4
Master Joatmon
Just ducty
Still wondering if the HVAC pros would know if it mattered whether I close off a zone at the branch origin (basement) or the branch end (register in the room).
The ductwork is only airtight with aluminum tape and caulk until it dissapears up into the walls and floors.
Old 08-21-2009, 03:32 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 92
It is better to close them at the branch. If you just use the floor registers they can be noisy after that as they don't seal 100%.
insulating duct work in basement Master Brian HVAC 10 05-19-2009 10:28 AM
Duct Work in Basement Handyman001 HVAC 1 03-02-2009 09:17 PM
Cutting a vent into basement supply duct jweiner HVAC 3 02-28-2009 12:56 PM
How Do I Install New Duct Lines For My Finished Basement? luweee HVAC 17 01-12-2008 03:01 PM
