Encapsulating & Conditioning Crawlspace -- Adding Supply Vents - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 10:04 PM   #1
This is my first post here, so bear with me if I miss something, but am hoping for advice as I encapsulate my crawlspace.
I've done a lot of reading here and elsewhere and plan to encapsulate my crawlspace in my split level home in Northern VA. The crawl space is about 700 sq. ft in area by 3 feet in height (to the top of the walls, not including rafters). There are two external vents that I plan to close and when I do so, I would like to add conditioned air to the crawlspace. Also, the floor is loose poured concrete and walls are block and testing for radon had no concerning readings. I plan to eventually insulate the walls and potentially add a vapor barrier, but there is no water issues, so I'm not in a rush there.
I have one large supply duct (but no return) that supplies heating/cooling to the main floor above. It would be fairly easy to add a vent or two to the main trunk here. My questions include the following:
A) Can I just add a supply vent without a return?
B) How many supply vents should I add?
C) Should I include a backdraft damper to the supply vent?
Thanks and let me know if there are other things I should be considering?
BadgerVA is offline   Reply With Quote
Old 03-17-2012, 10:05 AM   #2
1. yes
2. One
3. yes
CrawlSpaceMoist is offline   Reply With Quote
Old 03-17-2012, 11:08 AM   #3
An old Tradesmen
Rewards Points: 6,582
Need to have a return.
Old 03-17-2012, 11:24 AM   #4
I would agree on GPabout the return, as all condtioned spaces require them, but this is an un-occupied space.
And why, Been, did you not make mention of the the fact that the main duct has no return in the occupied space it serves?
And furthermore, Beenthere, how do you justify adding a few supplies opening to the crawl with out knowing the size of the supply duct or the air flow it's providing?????
hvac5646 is offline   Reply With Quote
Old 03-17-2012, 11:31 AM   #5
An old Tradesmen
Its getting its return from another area open to the main area.
Never said anything about adding supplies to that duct. Only said it will need return.
Old 03-17-2012, 11:34 AM   #6
But by omitting the supplies from your answer your are endorsing them by omission.
Old 03-17-2012, 11:36 AM   #7
An old Tradesmen
I simply answered the question that the previous posted has wrong.
Old 03-17-2012, 11:38 AM   #8
Who had wrong
You had wrong you mean?
Old 03-17-2012, 11:40 AM   #9
An old Tradesmen
Who had wrong
Nope. My answer is correct.
Old 03-17-2012, 11:48 AM   #10
Dmnit..which one?
Old 03-17-2012, 11:50 AM   #11
An old Tradesmen
The one about just adding a supply without a return.
Old 03-17-2012, 12:00 PM   #12
..and you agreed with me.
Old 03-17-2012, 12:02 PM   #13
An old Tradesmen
Simply answered 1 question.
Old 03-17-2012, 01:13 PM   #14
Glad you concur
Old 03-18-2012, 07:52 AM   #15
Now slightly confused
Ok, thanks for the lively "debate" -- but I'm now somewhat confused.
As I understand...
1) I SHOULD add a vent; and only 1 vent for the size of my crawlspace
2) I DO NOT need a return as this is an unoccupied space and it will slowly pull air from the surrounding space (through crawl space door, through seams/gaps naturally occurring in flooring above, etc)
3) I SHOULD use a backdraft damper when adding the supply
Can you all confirm this is the right interpretation of the input? Thanks!
Tags
crawlspace
condensation drips from supply vents denemante HVAC 9 06-19-2011 04:33 PM
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 09:30 PM
Questions about sealing a crawlspace. John_W HVAC 5 07-11-2010 03:24 PM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
Moving supply and return vents N8E HVAC 1 09-30-2008 11:25 PM
