Enable Humidifier With Fan? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 03:30 PM   #1
Enable Humidifier with Fan?
Hi guys,
I have a 2006-era Lennox High Efficiency Furnace (no AC) and a flow through pad style humidifier.
We'd like to enable the humidifier whenever the fan comes on, but right now it's only when heat is enabled.
I see that the solenoid that controls the waterflow to the humidifier is connected to the furnace's logic board. Is there a connection there I can change so it kicks in with the fan and not with just heat?
Thanks from a dry and itchy Canadian who wants humidification with the summer fan and not just with the heat!
amorak is offline   Reply With Quote
Old 09-09-2012, 06:28 PM   #2
HOTDAWG
The reason that it's wired that way is because you only want to use the humidifier in the winter.
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
Old 09-09-2012, 06:30 PM   #3
HOTDAWG
If you still want to run it anyway.. I would advise otherwise... you can wire it to G and C
The Following User Says Thank You to Acomfort For This Useful Post:
amorak (09-09-2012)
Old 09-09-2012, 07:17 PM   #4
Keeping in mind that not much humidity will be released into the air as the humidifer humidty process does rely on the furnace to warm the air so it can absorb the moisture
hvac dude is offline   Reply With Quote
The Following User Says Thank You to hvac dude For This Useful Post:
amorak (09-09-2012)
Old 09-09-2012, 10:47 PM   #5
Acomfort and hvac dude: Thank you both for your prompt and helpful replies! I realize that there is minimal benefit to running the humidifier sans hot air, but the air in Calgary is very dry in the fall and spring, but it's still not cool enough for the furnace... So I was looking for any incremental moisture I could add to the house, since we have a new baby and need some more moisture in the air for him.
In tandem with enabling the humidifier on the "G" line (which I believe enables it whenever the fan is on, can you confirm?) I have also added a vaporizer-style room humidifier to the baby's room, so if that works I will re-wire the humidifier back to the "W" line from the "G" line I've moved it to.
Thanks again!
[edit] I should add I tested the wire change to G by turning the humidifer on with the furnace fan on, and I hear water - if I turn the humidistat lower and it clicks off, I hear the water stop - so I think it's working! [/edit]
Old 09-09-2012, 10:49 PM   #6
HOTDAWG
Yup, G and c will run the humidifier whenever the fan is turned on.
amorak (09-10-2012)
Old 09-10-2012, 12:17 AM   #7
Thanks! One is connected to G the other goes up to the humidistat, so I assume that's the "C".
Humidifier Wiring to HAi Omnistat cipherman HVAC 10 11-09-2014 01:34 AM
RUUD Silhouette II Bypass Humidifier problems Oleh HVAC 8 01-06-2012 03:38 AM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 05:26 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 10:10 AM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 08:42 PM
