Old 03-28-2011, 12:57 AM   #1
empty Jug Weight
Hey guys,
I want to find out how much R410a is left in the jug. Its the 25# pink jug. I imagine that this is standard all across the country. How much does this weigh empty?
Thanks!!
MikelTee is offline   Reply With Quote
Old 03-28-2011, 05:46 AM   #2
An old Tradesmen
empty Jug Weight
About 6 pounds.
Old 03-28-2011, 11:57 AM   #3
empty Jug Weight
ALright. Thanks!
Old 03-28-2011, 12:41 PM   #4
empty Jug Weight
My full tank was 33 lbs.
DIY_HVAC is offline   Reply With Quote
Old 03-28-2011, 07:03 PM   #5
An old Tradesmen
empty Jug Weight
In or out of the box?
Old 03-29-2011, 12:27 AM   #6
empty Jug Weight
Out.
I decided to weigh it and write the weight on the tank every time I use it.
Old 03-29-2011, 05:17 AM   #7
An old Tradesmen
empty Jug Weight
Out.
Thats 2 pounds heavier then my empty weighs. Different manufacturers use different compositions though.
Old 03-29-2011, 10:58 AM   #8
empty Jug Weight
Just a related question. How accurate are the readings on your scales? Is it necessary to have a hard, level surface on which to put the scale?
V
veesubotee is offline   Reply With Quote
Old 03-29-2011, 12:18 PM   #9
empty Jug Weight
I use an actual refrigerant scale. It is accurate to 0.25oz. I use in on a pretty level surface.
Old 03-29-2011, 12:20 PM   #10
empty Jug Weight
V
Yea I don't know my brand.
Old 03-29-2011, 06:02 PM   #11
An old Tradesmen
empty Jug Weight
Pretty much all scales(that you set the jug on) must be on a hard level surface to be accurate.
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Insulating window weight pockets sergv General Discussion 2 11-02-2008 06:34 PM
Scissor Lift - How Much Weight??? JackOfAllTrades Building & Construction 9 09-08-2008 06:57 AM
Stone Veneer Weight kinglerch Building & Construction 2 08-28-2008 10:39 AM
Concern about beadboard weight dphardy Carpentry 4 10-12-2007 03:44 PM
