Emerson Motor Pdf - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 11:53 AM   #1
Emerson Motor Pdf
I have an Emerson Motor K55HXLGG-3702 Pt. No#51-19069-02. 1/2 Hp 115v. 60Hz 9.6Amp 1Ph 1075/4Spd 7.5Mfd 370v Cap. Came out of an Elc. Furn. Kept it as a spare, has no Digm plate. When un wired it, I wrote on it White Common, Black Hi, Blue Med, Yellow Med/Low, Red Low andBrown Capacitor. It only has 1 (one) Brown Wire. I thought that the other line to the Cap went to a relay that triped the Cap when the Blower started. I can't find anything about it from the Emerson sight, it just gives me the Replacement motor specs which has 2 (two) Broen Cap wires.
I read on a Form on Yahoo that 1 person was running it with the Yellow as the second Cap lead. I ask this because I had a replacement for my Trane XL1000 and a friends went out and I gave hime my replacement by mistake and now I have to use this one. Can anyone help me here? Thank you
tysfamily is offline   Reply With Quote
Old 10-02-2010, 03:51 PM   #2
An old Tradesmen
Rewards Points: 6,550
The white goes to the opposite side of the cap from the brown.And then a wire from the common of teh furnace goes to the same terminal as the white wire.
Some 240 volt motors use Yellow as the common. Your 120 volt doesn't.
Old 10-02-2010, 03:52 PM   #3
Well I was hopeing that someone would know how to wire up the Capacitor, I belive that it's a Start/Run Capacitor not just a Start Capacitor.
Old 10-02-2010, 03:54 PM   #4
An old Tradesmen
Its just a RUN cap, its not a start and run cap. They don't make such a thing.
Old 10-02-2010, 03:59 PM   #5
OK so from what I'm understanding here is this. If I wanted to run it on High I would put the Hot Led on the Black, Then the Brown would go on 1 side of the Capacitor and the White and the Common go on the other side of the Capacitor. Is this correct, because after i posted this I did a Google search and 1 form said to put the white and the common on the other side of the Cap.
Old 10-02-2010, 04:03 PM   #6
An old Tradesmen
What you said is correct.
The Following User Says Thank You to beenthere For This Useful Post:
tysfamily (10-02-2010)
Old 05-02-2012, 11:54 AM   #7
I have one of these fans as well but I want to use it as a floor fan in my barn. Has anyone wired this up as a multi-speed fan? If so, how?
Muskiemo is offline   Reply With Quote
Old 05-02-2012, 04:58 PM   #8
An old Tradesmen
You could use a 4 pole rotary switch.
Old 05-02-2012, 09:00 PM   #9
Thanks, I'll start looking around for one. Anyone know a good place to get one?
Old 05-02-2012, 09:04 PM   #10
An old Tradesmen
Should be able to find them for sell online. or possibly at your local electrical supply house, or farmers hardware store.
emerson pryne kitchen exhaust johnny rebel Electrical 1 04-07-2010 09:54 PM
