Old 12-27-2007, 02:37 PM   #1
Electronic Ignition Furnace will not stay burning
Hi i got a question i do volunteer work for a church and I've fixed many of furnaces before but they always used a pilot light. this one I'm trying to fix now uses Electronic Ignition and the igniter was clearly bad. I replaced it and now it lights but after about 25 to 30 seconds it shuts down. Then restarts the proses and when its burning its working correctly. What senses the flame? because it acts like its not sensing the heat and keeps retrying to light.Thank you.
Drennen is offline   Reply With Quote
Old 12-27-2007, 11:16 PM   #2
Union HVAC Tech.
There should be a flame sensor that looks like a small spark plug, it just needs to be cleaned with emory cloth. If it doesn't have a seperate sensor, the igniter is the sensor, was it replaced with an exact replacement? What is the furnace brand and model?
bigMikeB is offline   Reply With Quote
Old 12-29-2007, 02:19 AM   #3
yeah. but does it matter witch side the wires plug in to? because the way they shipped it. the wires was not pushed in to the plug holder. how ever nether wire was marked. Thanks for the quick reply
Old 12-29-2007, 02:20 AM   #4
Union HVAC Tech.
It makes no difference. It just has to be mounted so it's in the flame.
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 05:14 PM
Furnace will not stay on allenzachary HVAC 32 09-21-2010 09:30 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
Oil burning forced air furnace.... good bad or ugly? moneymgmt HVAC 2 06-21-2007 12:01 AM
