Electricty Bill Doubled... Heat Pump? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 11:11 PM   #16
Rewards Points: 33
Gotcha. So should I try turning it off altogether? I was under the impression that the HRV actually reduced the workload of the heat pump due to the fact that it recirculated the already warm air from the house through the system. Not the case?
jools is offline   Reply With Quote
Old 02-14-2010, 11:17 PM   #17
An old Tradesmen
Rewards Points: 7,344
It removes stale air from the house. This stale air, is air you paid to heat.
It brings in fresh air. From the cold outside in the winter. Air that has to be heated.
The HRV contains a heat transfer core. that transfers some of the heat from the stale air to the fresh air.
Some HRV's are only 40% efficient, others are 60% or a little more.
Old 02-14-2010, 11:30 PM   #18
Rewards Points: 33
Old 02-15-2010, 04:15 AM   #19
An old Tradesmen
No.
If you do that, then you will have no heat.
I suspect it has been a bite colder then in the previous year or 2. And that one of your strip heaters is not working right. And your aux heat is coming on. That you just may not be taking notice to.
You may want to check to make sure that all of your breakers are on.
Unless you have meters, your going ot have a hard time tracking down what is causing your high electric bill.
You may want to call in a contractor to check the heating system out.
This may not be caused by your heating system.
Old 02-15-2010, 09:51 AM   #20
Rewards Points: 33
No I meant just turning off the HRV. Would that kill my heat altogether? As far as outside temperature, it's actually been a little warmer than the previous two years, however you're right, it's completely possible that the Aux Heat has been coming on and I just haven't noticed it at that exact time. And again, I also agree, my heating system may not be causing this. I just figured it was the best possibility as it would have been the only think running while I was away, and the consumption was still high.
Old 02-15-2010, 07:18 PM   #21
When a customer with a HP has a bill that doubles over the course of a month it is related directly to the strip heat run time in about 98% of all cases I have ever seen.
brandonmcginnis is offline   Reply With Quote
Old 02-15-2010, 08:44 PM   #22
An old Tradesmen
You can turn your HRV off. It won't affect the heating system.
Old 02-16-2010, 07:24 AM   #23
Rewards Points: 33
Is there anything I can do to check out the heat strips or is it time to call somebody in?
Old 02-16-2010, 02:11 PM   #24
An old Tradesmen
Do you have an electrical meter?
Old 02-16-2010, 03:29 PM   #25
Rewards Points: 33
As in a multimeter?
Old 02-16-2010, 03:40 PM   #26
An old Tradesmen
Yes.
You will want to check if the strip heaters are broke(ohm them, power off). Or if they are coming on because of a stuck relay.
Old 02-16-2010, 04:01 PM   #27
Rewards Points: 33
What kind of resistance reading should I be getting across each one?
Old 02-16-2010, 04:13 PM   #28
An old Tradesmen
Depends on what KW it is.
Generally 10 to 12 ohms.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 02:26 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 09:46 PM
Heat pump thermostat emergency switch joe913 HVAC 2 12-10-2009 12:54 PM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 07:55 AM
