Electrical Wiring Running Parellel And Through Ductwork? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-01-2007, 07:47 AM   #1
Electrical wiring running parellel and through ductwork?
I keep finding interesting things in this rental home. The basement has an open ceiling in most areas. The "duct" leading to the external compressor is sheet metal nailed over a pair of floor joists to turn them into a duct.
However, it appears than when it was installed, the installer didn't worry about the electrical wiring that was already going through those joists. There are about eight wires which go through those joists, parallel to them, and most of them are through holes that aren't sealed well.
Thoughts?
Beren is offline   Reply With Quote
Old 06-01-2007, 10:15 AM   #2
Diesel Fitter
Rewards Points: 150
Its most likely a return duct and is OK. where is the filter?
mikemy6 is offline   Reply With Quote
Old 06-01-2007, 02:09 PM   #3
Home Improvement Guy
ron schenker's Avatar
This is a bit of a grey area codewise. In the event of a fire that wire will burn off noxious fumes. Personally I think it's a lazy man's way of running wire and I would never do it, even if I was lazy.
ron schenker is offline   Reply With Quote
Old 06-01-2007, 07:28 PM   #4
Diesel Fitter
Rewards Points: 150
I agree. But knowing landlords I dont see a wireing job in this guys future. If ya know what I mean. Thanks Ron!
Old 06-02-2007, 12:32 AM   #5
Oldbie
It's not code and it's not safe.
The wires should isolated and the return should be fireproof. If that isn't going to happen, then there's no other advice I could give.
mrtech is offline   Reply With Quote
