Old 12-28-2012, 03:16 PM   #1
electric water heater
I am going to build a detached garage w/ in law suite about 100' from house. Assuming capacity is adequate, would this be too far to use same water heater? north Georgia.
ugabulldog is offline   Reply With Quote
Old 12-28-2012, 03:42 PM   #2
Part of the Clover Leaf
impractical for sure.
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
ugabulldog (12-28-2012)
Old 12-28-2012, 03:52 PM   #3
Needs it's own water heater.
Better check with zoning and the health dept. to see if doing this is allowed and if it's going to need it's own septic.
Old 12-28-2012, 03:59 PM   #4
It will work just fine, now weather it is a code violation or not is another story thou!
But it would be better to install a water heater.
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
Old 12-28-2012, 04:04 PM   #5
Ya if you do not mind waiting 10 min. and wasting water.
Old 12-28-2012, 04:15 PM   #6
An old Tradesmen
Too far.
Old 12-28-2012, 04:28 PM   #7
Originally Posted by beenthere View Post
Too far.
Agree.
Impracticable: Yeah you could do it....but the problems out weigh benefits.
Old 12-28-2012, 04:31 PM   #8
ok, another one it is...thanks all
Old 12-28-2012, 07:05 PM   #9
great idea...you will be a lot happier
carmon is offline   Reply With Quote
Old 12-28-2012, 07:09 PM   #10
yep agree with others ...to far ...best to install its own ...ben sr
electric water heater shut off caryn keeper Plumbing 8 02-28-2012 07:39 PM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
