Old 01-11-2012, 05:25 PM   #1
011010100110111101100101
Electric wall heaters
Was curious how many of you guys, if any, have played with the newer electric wall heaters? I'm looking at the farenheat smart series:
http://www.smartseriesheat.com/products/wall-heater/
I have a house that is roughly 900 square feet. It has a poorly installed steam system, that is way way over fired (boiler is like 130k btu), and the boiler seems to have some other issues. I have renovated the home, adding 700 additional square feet. Walls and ceiling are all insulated to 2010 energy standards including windows.
So anyhow, the home is primarily heated with wood stove. The sucker runs day and night, burning 5-6 cords per year. The oil system is to backup the stove when I'm not home, say I'm gone for 10 hours and I want to maintain 60 degrees.
I have to remove the boiler and re-do the system due to code violations anyway. Obviously I have a number of options, oil, propane, electric - forced hot water, forced air, etc. I've done some cost calculations and roughly propane and electricity are the same price per million btu's, and oil depending on the week, is a little cheaper or the same. Oil obviously needs to account for maint costs of the boiler. This is also based on the efficiencies of locally obtainable furnaces and devices, not a $5,000 mod/con boiler - aint happening.
So, I'm honestly thinking about putting one of these 2,000 watt units in each major room, and placing smaller units in the two bathrooms.
The other option is a propane fired forced hot air or water. I've priced out furnaces, duct work (or plumbing), and the initial costs are quite comparative with installing an electric unit in each room, but the labor is intense. Running ductwork in the old section of the house where the crawl space is less than 20 inches would be horrible. Even running pex/copper to support radiators wouldn't be fun.
So, who has used these units and what is your feedback?
-- Joe
anesthes is offline   Reply With Quote
Old 01-11-2012, 05:34 PM   #2
MarginallyQualified
I'd only use electric heat if I had NO OTHER choice whatsover
(or someone else was paying the power bill)
I have a house that is roughly 900 square feet...
Walls and ceiling are all insulated...
that is way way over fired (boiler is like 130k btu)...
This is your answer.
Run the pipe, scrounge up some radiators, put in a few valves.
There is NOTHING better than steam heat.
hth
Old 01-11-2012, 05:47 PM   #3
-- Joe
If that is really true (I doubt it) then it may be a good idea. I would first buy one and try it out, they can be noisy and the heat they put out may not heat the room evenly. You will need upgraded electric service too and that meter will spin!
bungalow_steve is offline   Reply With Quote
Old 01-11-2012, 06:04 PM   #4
I put a new panel, meter socket, SE in a couple years ago at 200A. So I'm ok there.
We're paying $3.50 / gallon for propane, and 13 cents per kwh for electric. That comes out to $40 / million BTU propane, and $41 / million BTU electric. If we use more wood, the propane goes up to $5.56 / gallon. (min 700 gallons to get the $3.50 rate). Electricity is always 13 cents.
It's not enough of a difference to matter. We're talking maybe $100 over the entirety of the heating system, and then if you add the cost of the power to run the (blower, circulators, whatever) it's null anyway.
But I'd like to hear of someone who has used THESE units. I've seen a million electric baseboards, but never a modern wall blower.
TarheelTerp - steam is. horrid. I've owned two houses now with steam. I'm done with it. You can come buy my radiators this spring at the garage sale
We're at the point where it's either electric, or forced hot air. Forced hot air is neat, but the install is outright hell in a crawl space!
-- Joe
Old 01-11-2012, 06:17 PM   #5
MarginallyQualified
fwiw... my sense is that your problem is with the controls...
The NEXT best heating choice is forced hot water.
You already have at least half of what that needs. Convert.[/quote]
There is no way in the world I'd choose FHA over FHW or steam. Ever.
Especially not when it was already installed.
Old 01-11-2012, 08:13 PM   #6
Especially not when it was already installed.[/quote]
The problem with both steam, and FHW is it takes 9 years to heat the house up. It's nice even heat, but it just takes forever.
Then, with FHW, it's the wall space issues.
The boiler I have is too big for the home anyway. Even if I put a smaller nozzle in it, it's over fired. Plus, I'm sick of oil.
-- Joe
Old 01-12-2012, 01:20 PM   #7
Ok, guess I'm used to $6/million BTU natural gas.
2000 watts delivers the same BTU's whether it's a $20 walmart spaceheater or $400 wall unit with a bunch of LED displays, you might try amazon for reviews
Old 01-12-2012, 04:38 PM   #8
$6 ? Har. We don't have NAT gas here. Propane or Oil.
I realize 2000 watts delivers the same BTU's but I wasn't sure of the overall efficiency of heating the room with the fan, and the logistics behind it being a box in the wall vs say a 8 foot baseboard.
-- Joe
Electric Fireplace built into the wall J187 Project Showcase 4 03-24-2011 04:00 PM
Electric baseboard heaters ? ants1929 HVAC 11 03-11-2011 09:23 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
