Electric Vs Oil Hot Water - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 09:08 AM   #16
An old Tradesmen
Rewards Points: 8,202
Originally Posted by Canucker View Post
It sounds like the next time I run into it, I'm better off running the electric completely separate then cranking the aquastats down. Still seems like a lipstick on a pig solution but what can you do, eh?
On old boilers, I leave the aquastat at 100. On newer boilers, I bypass the reverse action and leave them as a cold start. The cold start ones use the least oil.
I sometimes pipe it up so that with a few turns of valves and a resetting of the aquastat they can use the boiler for domestic water if they want.
The Following User Says Thank You to beenthere For This Useful Post:
COLDIRON (09-03-2012)
Old 09-02-2012, 08:11 PM   #17
Thread killer
Rewards Points: 272
I like the second option, a few extra valves won't break the bank and it would give the homeowner options in the future. Thanks
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 09-03-2012, 10:34 AM   #18
I don't know whether the boiler is a warm start or cold start... or even what the means exactly I'm pretty sure this is the boiler we have: http://www.weil-mclain.com/en/our-pr...il-boiler.aspx
I do know that when we first bought the house I was looking all over the basement for the water heater and realized "There isn't one!" and I thought this must be the more efficient way to do things since the boiler was brand new. However the people who owned the house before us cut every corner possible, so it was probably just cheaper to forgo the hot water heater.
So, would it wiser to install the electric heater now, or wait until the spring?
gbook2 is offline   Reply With Quote
Old 09-03-2012, 11:33 AM   #19
An old Tradesmen
Install it now, and you reduce your heating bill this winter.
Your boiler is a warm start, since it must maintain temp to provide you with hot water.
Old 09-03-2012, 12:38 PM   #20
Rewards Points: 610
From what I have just researched, yes, your boiler is currently a warm start as stated...all that means is, that is the mode of operation...Once reverted to heating only then, it is a cold start...As to your question..the sooner you install electric WH the more you will save (all this depending on your cost of electricity...we are at approx 9 - 15 cents per kWh depending on time of use..However, it won't be a huge difference over one fall and winter...Change asap in April if you need more time to budget..
techpappy is offline   Reply With Quote
Old 09-04-2012, 12:09 PM   #21
Rewards Points: 610
Hey Canucker! Thanks for the reference to the commercial Industrial Steam forums..very interesting so, I registered there.
TechPappy... Retired Boilerman and Building Mechanical Systems Specialist?? That's what my title was anyway Covered all of Ontario and when the specialists couldn't find it or fix it I was called in to Trouble shoot ..but, never afraid to ask questions ...and go to the ends of the earth to fix a problem or find someone else with answers. Still Learning!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Not Enough Hot water in the shower from a 40 Gallon Electric Hot Water Heater. rcake Plumbing 10 06-10-2011 12:20 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
