Old 03-26-2011, 07:15 PM   #1
Electric Thermostat
I had a goodman thermostat model # HPTD18-60. It quit working so I tried to replace it. the new thermostat i got was a honeywell RTH3100c. After installing i tried to see if the heat would kick on but nothing happened... what should I do..
Psamons is offline   Reply With Quote
Old 03-26-2011, 07:56 PM   #2
Professional
Electric Thermostat
sounds like a heat pump thermostat, please terminal designations of old thermostat and color of wires of old thermostat. Have you checked the breakers and or fuses in and for the HP and air handler?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-27-2011, 04:01 PM   #3
Electric Thermostat
I made sure all wire were connected to the appropriate places.. marked wires before replacing... it still did not work.. any other suggestions checked breakers for furnace.. not sure what else to check..
Old 03-27-2011, 04:12 PM   #4
Professional
Electric Thermostat
if you don't post the old terminal and what connected to on the new stat we can't help, you telling us that they are correct doesn't prove they are correct. check for a low voltage fuse blown in indoor unit as stated before. If you don't want to post terminal designations. Other than that, with out more info we can't help.
IT IS WHAT IT IS
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
thermostat wiring for electric heater Captflx HVAC 3 03-05-2010 09:48 PM
thermostat and humidity controls for electric attic fans lowlysubaruguy Roofing 2 09-25-2008 08:32 AM
Honeywell Electric Thermostat Model T498 staylori HVAC 1 01-14-2006 01:25 PM
