Electric Radiant Cove Heater For Bathroom? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 02:14 PM   #1
Rewards Points: 95
Electric radiant cove heater for bathroom?
These are new to me. I'm looking for a little supplemental heat in a master bath. We currently use a wall-mounted electric heater but it's a hassle turning it on since it doesn't have a thermostat (and can't use one, in case you were going to suggest that. We're looking at the cove heater as a replacement. Has anyone used one?
For our application it only has to bump the temp up maybe 2F or 3F, not much heat really.
There are several brands out there, but this is just one of many:
http://www.radiantsystemsinc.com/
garya505 is offline   Reply With Quote
Old 11-13-2013, 02:29 AM   #2
Rewards Points: 95
Anyone?
Old 11-13-2013, 04:49 AM   #3
An old Tradesmen
Rewards Points: 8,142
Doesn't look like a unit that you turn the heat up and down, looks like a set it and leave it unit. Radiant heat is slow.
The Following User Says Thank You to beenthere For This Useful Post:
garya505 (11-17-2013)
Old 11-13-2013, 06:09 AM   #4
Rewards Points: 1,216
Just buy a small electric element heater from big box store and a line voltage thermostat and run the wire behind the wall from the heater to the thermostat.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Electric Baseboard Heater Wiring Help ryanb4614 Electrical 19 09-28-2012 07:30 PM
Electric heater and venting and freezing jackwashere Appliances 2 09-28-2012 06:51 PM
Trouble With Electric Hot Water Heater whitedavidp Plumbing 8 04-22-2009 05:16 PM
Replacing a Water Heater with Electric One 2031pratt Plumbing 3 12-26-2008 09:17 AM
