Old 01-27-2011, 05:12 AM   #1
Electric heater runs for 10 minutes, goes off for 2
Electric heater runs (box type tied into the a/c blower) for 10 minutes, goes off for 2, even though it didn't reach the set temp. Is this normal?
What kind of regular maintenance are you suppose to do to those? Annual cleaning?
TIA
abefroman is offline   Reply With Quote
Old 01-27-2011, 07:49 AM   #2
Sounds like the electric heater is cycling on a limit switch. Check for low air flow, make sure all the registers are wide open as well as return air grills.
fitter1 is offline   Reply With Quote
Old 01-27-2011, 08:57 PM   #3
Now it seems to stay on for 5, then go off for 5.
Could it be some kind of overheating sensor shutting it off? Bad thermostat?
Old 01-28-2011, 08:06 AM   #4
The filter is new, but its one of the 700 microparticle ones, should I try a regular filter?
Which ones are the best?
Turning off electric water heater when not in use? skipjack Green Home Improvement 10 03-08-2011 10:02 PM
Why does my air handler have an electric heater elcid HVAC 3 01-17-2010 03:52 PM
selecting an electric water heater reds_21 Appliances 7 05-23-2009 02:48 AM
How safe is an electric heater? Circuit breakers Appliances 1 01-05-2009 12:49 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
