Electric Heat Pump Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 08:28 PM   #1
Question
electric heat pump issue
when turning inside thermostat on heat mode, the heat pump kicks on, heats to proper temp then outside fan kicks off, leaving system to run in an ongoing fan mode. we have to either adjust thermostat temp below its setting to make it kick off or switch thermostat to off mode and wait for system to kick off. any ideas why this could be happening?
gator5220 is offline   Reply With Quote
Old 11-29-2010, 05:37 AM   #2
An old Tradesmen
Rewards Points: 6,068
Is the thermostat's fan switch in the "on" position? If so, set it to auto.
Could be a limit switch in the air handler is open.
Old 11-29-2010, 10:00 AM   #3
Rewards Points: 392
Sounds like it could also be defrost mode and bad luck with your timing.. Are you sure it's not in defrost mode? What is your backup heat? Electric or gas?
Are you familiar with defrost mode? It basically runs the heatpump in reverse without the outdoor fan running, then after a while steam comes off the heatpump and the fan kicks back on.. Meanwhile the indoor blower is running, putting cool air over the indoor coils. The coils are actually getting cold inside so that heat can defrost the coils. It is running in AC mode to defrost the outdoor coils..
One way to check if you are going into defrost mode is to go out side and listen to the heat pump. If the compressor is running but the outdoor fan is not turning, you're in defrost mode. A lot of heat pumps this time of year go into defrost mode every 45 minutes or so to keep the coils from icing up.
zootjeff is offline   Reply With Quote
Old 11-29-2010, 10:31 AM   #4
Bla bla bla
its in the T-Stat period.......
cypressrepairs is offline   Reply With Quote
Old 11-29-2010, 10:40 AM   #5
And Still Learning
Gator, you have described "defrost mode".
It's been 31 years since I was in AC/Refri school. I forget, what determines the length of time a defrost cycle needs.
Last winter we had a cold day of rain. The temp was one degree above freezing. Seems like the heat pump at work went into defrost cycle way more than normal. The fan stopped turning. Finally we had to carefully remove the ice from the outside condensor because it was stopping the fan from rotating.
Know It ALL is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Heat pump vs. Radiators - Opinions/Recommendations rflail HVAC 7 11-10-2010 10:56 PM
Electric furnace with heat pump ErikB HVAC 2 11-07-2010 05:44 AM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 11:28 AM
