Electric Heat Pump Gas Ack -- NO GAS! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 07:18 AM   #1
Yardley, PA
electric heat pump gas ack -- NO GAS!
Hey guys,
Dire straights here. We have an electric heat pump that has propane backup. I guess its too cold for the electric heat pump to be efficient so its running in backup mode? Temp has been in the teens past few days.
What ever the reason, we are having problems with our propane (not getting enough pressure into the house to run any of our gas appliances)
The owner of the buried tank is Amerigas. They are being, well, less than useful at this time.
So, is there any way to get the heat pump to run back in electric mode with the outside air handeler? Will it even generate heat?
Thanks guys, in a tight spot with limited options.
Bryan
BJohnston is offline   Reply With Quote
Old 01-25-2013, 11:42 AM   #2
Disconnecting w on the furnace and placing a jumper wire between w and y at the thermostat should do it.
Old 01-25-2013, 11:52 AM   #3
Roofmaster
Rewards Points: 2,172
Isnt asking a heat pump to heat your house in 15 degrees, Im sure with wind asking a lot? Is your gas tank full? or do you have funzalow disease?
Old 01-25-2013, 12:42 PM   #4
Yardley, PA
Asking a heat pump to do that is certainly a stretch. But when its 50 degrees in your house, even if it heated the air to 51 degrees it would be awesome.
Luckily, they came out and fixed our propane. Ended up being a frozen regulator. Hopefully will never have to deal with this again.
Thank was at 55%, while the funzalow disease runs rampant in our house - it applies to my shop and not essentials.
Old 01-25-2013, 12:51 PM   #5
Roofmaster
Thank Goodness for that. And I too know why the bottom guy on the totem pole's shoulders slump, his eyes bug out, and he has high blood pressure. Its the weight.
Old 01-25-2013, 07:15 PM   #6
Missouri Bound's Avatar
A heat pump loses it's heating capacity as the temperature drops. However I use mine exclusively, and when it's 15 degrees outsidi it still works fine.
Do you want it your way or the right way?
Drainage under packaged heat pump salonica HVAC 18 12-25-2011 07:07 AM
Heat Pump Crisis Part II Doc Holliday HVAC 58 12-07-2011 09:14 PM
Heat Pump Crisis, Help! Doc Holliday HVAC 14 12-02-2011 09:22 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 02:26 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
