Electric/Gas Fireplace Won't Start - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 12:04 PM   #16
how
Rewards Points: 1,104
I am not sure that I would agree that this cloth gasket is delicate. You will need to remove screws at the bottom of the front. If there are no screws on the top fronting then the fireplace glass facing & frame is hooked on a top lip. All removal actions must be done with the attention to not twist or bend the glass & frame during the removal process or you've suddenly cost yourself a couple of hundred bucks. Some fireplaces have loose glass in that frame so you need to not allow the glass to fall out when removing it. Many of many of my clients regularly remove the glass for cleaning but they probably have the owner's manuals to help them. You can post pictures of anything you are not sure of.
how is online now   Reply With Quote
Old 03-03-2012, 02:27 PM   #17
Rewards Points: 31
Hey guys,
So, I checked, and the dial won't turn any further - there is actually a white line on the set where the ON currently is, so I'm fairly positive that it is set to ON. Aside from that, there's no switch on the side of the unit, nor is it set to a light switch inside - being as though it's plugged into a wall outlet, I'm thinking that the ON switch as it were would need to be somewhere on the unit itself, but I can't find one for the life of me. Going to maybe grab a flashlight and dig underneath some more, see what I can see.
GordCooper is offline   Reply With Quote
Old 03-03-2012, 02:31 PM   #18
Rewards Points: 31
WOW
TINIEST rocker switch on Earth was located at the bottom right, outside the unit. Looks like we're cooking with gas now
Thanks for all the assists guys, it was a tech support "HAVE YOU CHECKED IF IT'S PLUGGED IN???" moment for sure.
Gord
Old 03-03-2012, 02:54 PM   #19
how
Great news!
Gas fireplace question - Who will save me? Pig General DIY Discussions 12 08-10-2010 09:34 AM
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 06:14 PM
Fireplace remodel -- need advise & suggestions mwehnes Building & Construction 12 06-28-2009 09:36 PM
Fireplace leaking mmcginn2 Roofing/Siding 4 04-23-2006 10:12 AM
