Old 01-04-2013, 04:52 AM   #1
Electric furnace woes!
Hello! I do believe I have a mess.
First off, I plan on replacing this "mess" in the spring but until then I hope someone can help.
I have this Goodman electric furnace in the attic, this is a heat-pump/electric furnace system. Since the outside temp is well below 35 degrees and my heat pump has a bad Freon leak I've opted the run solely on the emergency heat setting using the electric furnace. Now for the "real" problem.
If I set my thermostat at, say 70 degrees, my furnace will come on as expected start with one icon of heat on the thermostat, then two. When the house get to 1/2 of a degree of the set point, the second part of the heating drops out and the darn thing just runs and runs. I spoke with a repairman and he said that Goodmans are designed this way. Just thinking that this cannot be right. Please help and thank you in advance!!!
dcaudill6572 is offline   Reply With Quote
Old 01-04-2013, 05:41 AM   #2
An old Tradesmen
Jumper W1 and W2 at the air handler or thermostat.
The Following User Says Thank You to beenthere For This Useful Post:
dcaudill6572 (01-04-2013)
Old 01-04-2013, 07:25 AM   #3
Thanks for your advice. What will that do?
Old 01-04-2013, 10:45 AM   #4
Was going to apply the jumper but I don't have a W1. I vaguely remember the one hvac tech that was here on a seperate issue told me I could move the white wire(W2) over to the E terminal with the black wire or visa versa. Later his boss said that would be a bad idea. Am I on the right track with what you're telling me? Also, am really going to make any improvement in heating and efficiency or am I just wasting my time with this mixed matched piece of junk? Thanks again!
Old 01-04-2013, 04:49 PM   #5
An old Tradesmen
Can you post a pic of the wires connected to the air handler. Also check what size breaker is connected to the air handler.
You would need to jumper from E to W2. If you moved the wires from W2 to E, you would have aux heat when the heat pump needed to use it.
Old 01-04-2013, 08:40 PM   #6
I got you on the jumper. I'll try to get the pics on tomorrow since it's late. Sir I really appreciate you letting me pick your brain on this. Thank you!
Old 01-04-2013, 11:36 PM   #7
An old Tradesmen
Your welcome.
Old 01-05-2013, 07:08 AM   #8
Professional
use emergency heat if you are not using the HP.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Tags
electric furnace, goodman, heating and cooling, heating problems, heating unit
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Electric Furnace Sammy 2 Electrical 2 11-20-2011 09:22 AM
Electric furnace with heat pump ErikB HVAC 2 11-07-2010 05:44 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
