-   -   Electric furnace woes! (http://www.diychatroom.com/f17/electric-furnace-woes-168195/)
dcaudill6572 01-04-2013 04:52 AM
Hello! I do believe I have a mess.
First off, I plan on replacing this "mess" in the spring but until then I hope someone can help.
I have this Goodman electric furnace in the attic, this is a heat-pump/electric furnace system. Since the outside temp is well below 35 degrees and my heat pump has a bad Freon leak I've opted the run solely on the emergency heat setting using the electric furnace. Now for the "real" problem.
If I set my thermostat at, say 70 degrees, my furnace will come on as expected start with one icon of heat on the thermostat, then two. When the house get to 1/2 of a degree of the set point, the second part of the heating drops out and the darn thing just runs and runs. I spoke with a repairman and he said that Goodmans are designed this way. Just thinking that this cannot be right. Please help and thank you in advance!!!
beenthere 01-04-2013 05:41 AM
Jumper W1 and W2 at the air handler or thermostat.
dcaudill6572 01-04-2013 07:25 AM
Thanks for your advice. What will that do?
dcaudill6572 01-04-2013 10:45 AM
Was going to apply the jumper but I don't have a W1. I vaguely remember the one hvac tech that was here on a seperate issue told me I could move the white wire(W2) over to the E terminal with the black wire or visa versa. Later his boss said that would be a bad idea. Am I on the right track with what you're telling me? Also, am really going to make any improvement in heating and efficiency or am I just wasting my time with this mixed matched piece of junk? Thanks again!
beenthere 01-04-2013 04:49 PM
Can you post a pic of the wires connected to the air handler. Also check what size breaker is connected to the air handler.
You would need to jumper from E to W2. If you moved the wires from W2 to E, you would have aux heat when the heat pump needed to use it.
dcaudill6572 01-04-2013 08:40 PM
I got you on the jumper. I'll try to get the pics on tomorrow since it's late. Sir I really appreciate you letting me pick your brain on this. Thank you!
beenthere 01-04-2013 11:36 PM
Your welcome.
hvactech126 01-05-2013 07:08 AM
use emergency heat if you are not using the HP.
