Electric Furnace Trouble - HVAC - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 08:48 PM   #1
Unhappy
electric Furnace trouble
The furance has only been in use since 2007.Last year my furance stopped producing quality heat and I discovered that a coil was not engaging, so I replaced that and found the smoke had escaped my sequencer-replaced that and the coil. The wiring seems simple and I had a qualified technian check the voltage and current to the switches after a coil went out after I replaced the Sequencer. Now this year, the furance is emmiting heat but the coil is not on. I hear a hum seems like only one coil is turning on again.
Depshado is offline   Reply With Quote
Old 01-22-2010, 10:41 PM   #2
An old Tradesmen
Rewards Points: 6,140
Probably another sequencer.
is this in an attic?
Old 01-23-2010, 01:17 PM   #3
like candy
Its in the hallway, a downdraft to floor vents. The trouble started when a moth flew up into the heating coils. Do I have to replace that every year? should I just upgrade the unit?
Old 01-23-2010, 02:21 PM   #4
An old Tradesmen
I'm taking a guess that the sequencer is the problem. In some attics they have problems on a regular basis.
Should be checked with a meter to find out what is wrong before taking action.
Old 01-23-2010, 02:21 PM   #5
A 3 year old furnace I would fix. Could be just a bad batch of sequencers that got used in your equiptment. Most last many years before failing, some never fail the whole life of the furnace.
Old 01-25-2010, 11:28 AM   #6
Cool
second question
Its a very noisy Furance so I was thinking I could add insulation to dampen the effect, where and what would I use? Inside or/and out?
Tags
electric furnace
Electrical Service Required for an Electric furnace brokenhammer Electrical 8 01-11-2010 12:02 PM
Need help with Electric Furnace and HP goodeetwoshews HVAC 7 12-17-2009 10:38 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
