-   -   electric Furnace trouble (http://www.diychatroom.com/f17/electric-furnace-trouble-62534/)
Depshado 01-22-2010 07:48 PM
The furance has only been in use since 2007.Last year my furance stopped producing quality heat and I discovered that a coil was not engaging, so I replaced that and found the smoke had escaped my sequencer-replaced that and the coil. The wiring seems simple and I had a qualified technian check the voltage and current to the switches after a coil went out after I replaced the Sequencer. Now this year, the furance is emmiting heat but the coil is not on. I hear a hum seems like only one coil is turning on again. :eek:
beenthere 01-22-2010 09:41 PM
Probably another sequencer.
is this in an attic?
Depshado 01-23-2010 12:17 PM
like candy
Its in the hallway, a downdraft to floor vents. The trouble started when a moth flew up into the heating coils. Do I have to replace that every year? should I just upgrade the unit?
beenthere 01-23-2010 01:21 PM
I'm taking a guess that the sequencer is the problem. In some attics they have problems on a regular basis.
Should be checked with a meter to find out what is wrong before taking action.
Marty S. 01-23-2010 01:21 PM
A 3 year old furnace I would fix. Could be just a bad batch of sequencers that got used in your equiptment. Most last many years before failing, some never fail the whole life of the furnace.
Depshado 01-25-2010 10:28 AM
second question
Its a very noisy Furance so I was thinking I could add insulation to dampen the effect, where and what would I use? Inside or/and out?
