Electric Furnace Sequencers - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 12:58 PM   #1
electric furnace sequencers
I have a blower that stays on for awhile. decided it is the sequencer. I could hit it and will shot off. If one is bad should I just replace them all. it is a 5 switch sequencer. 24a34-14 white rogers I tripped the breaker a couple of times in the garage, about a month ago. figured that was unrelated.
tom anderson is offline   Reply With Quote
Old 11-08-2012, 02:15 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Sequencers are designed to bring on one strip at a time so as to not pop the breaker, to not over amp the circuit. If that happened than I'd change them all.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 11-17-2012, 01:29 AM   #3
Blower stays on.
After running my Furnace for a while. 20-30min. The blower/fan will stay on at the low speed. It will run on low for about 30min to an hour. I would give it a hit and it would shut off. (would hear switches closing/opening as well). I believe it is the blower motor relay. It is an old furnace but found a replacement part. However, to save money, can these swtiches be taken out and cleaned? Should I slide the lever Down to 80-85 or up to 95? (it is a sliding lever). Here is the old part #F214-14A9-140-25C. I have another switch. that I think does the high speed blower part#F47TS2-7T-110C , (this number was the best I could read it). Thoughts?
Electric Furnace Sammy 2 Electrical 2 11-20-2011 08:22 AM
Two Stage Electric Furnace burnt03 HVAC 10 01-13-2010 10:28 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
