Electric Furnace Isn't Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 07:32 PM   #1
Exclamation
Electric Furnace isn't heating
Greetings,
I have issues with my furnace and I'm wondering if it's a simple fix or not. I've had the landlord take a look at a couple of times last year during the winter, but now it appears the same thing is happening.
I've recorded a sound, but let me explain the situation. The thermostat, recently replaced (recently being within this year), reports 68 degrees. Temp it's supposed to be is 73 to 75. This is obviously not correct. The furnace seems to turn on, and I see the flame in the furnace through the grates, but no heat from the vents. Air conditioning works fine (I understand this is supposed to work with the heater, so felt it might be worth mentioning) and when I turn on the fan manually (flipping the switch from Auto to on) it appears to blow air (wouldn't call it hot, ambient maybe).
One thing I don't remember happening last time is that there is this buzz. Sort of like what you would hear if electricity shorts. I remember asking about it, and it was said it's normal to a point, as I did hear it upon the first start, but it would disappear.
Let me know if I should upload the sound, and where. It's taken with my cell phone, but you can hear it once or twice on the recording.
demortes is offline   Reply With Quote
Old 09-20-2010, 12:37 AM   #2
Seasoned DIYer
Rewards Points: 150
It's not an electric furnace if you see flame. Send a written notification to landlord and ask for it to be repaired. I don't know how cold your area is, but you have certain rights as a tenant to have it corrected immediately.
HVAC_NW is offline   Reply With Quote
The Following User Says Thank You to HVAC_NW For This Useful Post:
demortes (09-20-2010)
Old 09-20-2010, 08:25 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by HVAC_NW View Post
It's not an electric furnace if you see flame..
let's hope it isn't an electric furnace anyway
Old 09-20-2010, 11:42 AM   #4
I thought the term electric meant it's pilot light. A flame is needed to generate heat. Either way, they are looking at it today. Just thought I'd get someone to listen in on it, cause it appears my landlords fixes are bandaids and I'm sick of relying on other ppl. I'm 24, I should know the basics :P
Tags
electric , furnace , wont heat
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 08:38 AM
Suntouch electric radiant floor heating reg Jim Anderson Electrical 3 10-25-2009 08:13 AM
New Electric Convection Heating Panels--Any Experience? akimbo HVAC 19 05-27-2009 11:42 AM
electric furnace not shutting off pkuenz HVAC 5 11-17-2008 04:22 PM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
