Old 08-26-2012, 04:45 PM   #1
electric furnace for hydronic radiator heating
i have radiator piping in place in my basement apartment but decided not to use gas in that apartment because i don't want to share it with the main unit and it's too complicated to get another gas meter. so i was thinking to still use the radiators but to somehow heat the water with an electric furnace/boiler.
i was wondering if there is such a product. i tried Google but didn't find anything.
or can i improvise my own by adding some kind of a pump to a regular electric water heater? and a thermostat
thanks
Old 08-26-2012, 05:48 PM   #2
An old Tradesmen
Hope your electric rate is only $0.02 a KWH or less. Or it a very small basement apartment that won't take much to heat.Most electric water heaters are not approved for space heating.
Old 08-26-2012, 06:25 PM   #3
OK, thanks. you think it'd be more efficient to use baseboard heaters? it is a typical small 1 BR apt., living room, kitchen, bath, little hallway, bedroom. i haven't hung DW yet so i could still run wire
Old 08-26-2012, 06:40 PM   #4
An old Tradesmen
6 one way half a dozen the other. With the exception that electric baseboard with a thermostat for each room can be cheaper then just an electric boiler, since the room temp control will allow for some rooms to be kept cooler when not in use.
The Following User Says Thank You to beenthere For This Useful Post:
amakarevic (08-26-2012)
Old 08-26-2012, 06:57 PM   #5
so if i use two big BB heaters and one little one for the bathroom, and wire them all on the same circuit, a 30A circuit 120/240V should suffice?
http://www.globalindustrial.com/imag.../ZBL-BLFOO.pdf
Old 08-26-2012, 07:08 PM   #6
An old Tradesmen
30 amp 240 volt.
Old 08-27-2012, 03:31 PM   #7
hey, can you please check out this new thread i just created?
thanks
need brand recommendation for baseboard heaters
Should electric furnace cutoff box be warm to touch when running? turboconn HVAC Site - PROS ONLY 0 12-17-2011 01:11 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Electric Furnace Sammy 2 Electrical 2 11-20-2011 09:22 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
