Electric Furnace Help!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 01:14 PM   #1
Electric furnace help!!!
My electric furnace will not turn off I changed the t-stat and still wont turn off what else could it be?
Leest is offline   Reply With Quote
Old 02-06-2011, 01:30 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
Won't turn off as in continuously blowing some heat? If so you probably have a stuck high voltage sequencer and need a service tech who does electric furnaces or an service electrician to check it.
The Following User Says Thank You to yuri For This Useful Post:
Leest (02-06-2011)
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
heat pump / ac unit vs electric furnace ellebt HVAC 4 01-12-2011 09:22 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
