Electric Furnace Gets Hot But No Air Blowing - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 12:22 AM   #1
Electric furnace gets hot but no air blowing
I live in a older mobile home that has an electric furnace. The furnace started not shutting off and the breaker box would get very hot. I would have to shut it off by turning the breaker off. Then one day when I came home you could smell something burning. When I went to check furnace it wasn't running but it was very hot and hot air coming out of intake vent. What could be causing this to happen?
freezinginKY is offline   Reply With Quote
Old 12-15-2012, 12:56 AM   #2
Rewards Points: 13,712
Hard to understand your post.
Is the blower running or not?
Got a make and model #.
If the blowers not running the furnace is going to get really hot because all the hot air is trapped in the heat chamber.
Could be lots of things, broken belt, bad capasitor, bad motor, loose wire ECT.
Old 12-15-2012, 03:25 AM   #3
An old Tradesmen
Rewards Points: 7,332
Could be a bad sequencer, or a bad blower motor or bad run capacitor.
What have you checked.
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 04:22 PM
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 08:38 AM
Electric Furnace question whatsthis HVAC 32 04-08-2009 07:39 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
